Baja Design Squadron Fog Lights
up4boating
Livonia, Michigan
I have a 2015 1500 Sport and I'm upgrading all the headlights. I added Morimoto HID low beams, GTR LED high beams and Baja Designs Squadron fog lights. I turned on HID and LED high beams in Alphaobd and those work great. I also turned on LED fog lights but when I hook up the factory fog light plugs to the two pairs of BD Squadron cubes they flash a couple times and then go out.
Is this something I can resolve with alphaobd or do I need to use an aftermarket harness and pull power off the battery?
CoreySinger
Canada
ecodiesel
Mine are on a separate harness. I plugged into the factory fog plug for signal to the relay. This way I use the factory switch.
Also set to led with alpha. The relay buzzed otherwise.
U
up4boating
Livonia, Michigan
Corey,
When you say you plugged into the factory fog plug, are you referring to the plug that physically clips onto the fog light bulb or are you talking further back in the system?
CoreySinger
Canada
ecodiesel
I plugged right into the bulb plug. This is instead of running power to a new switch and then to the relay.Found the right plug pigtail on Amazon. I made an adapter for the driver side and a plug for the empty passenger bulb spot.
Fatboy1989
