rjerje16148
I have a 2011 ram 1500 5.7 . I had a dead battery, jump started it to get to work then jumped again to get to the parts store for new battery. My issue after the battery replacement my master window switch quits working for the power locks, power mirrors, and front windows. Fuse is not blown but if I remove the fuse and reinsert it all will work like it should. The issue reappears every now and the seems like it I turn the ignition key to fast it happens again. Has anyone else had this happen to them and what is the fix ? Also if i could find a wiring diagram that might help !
