Eaglefire21
Dealer turned on battery saver mode instead of replacing battery's. Now I have new battery's and need to turn off battery saver mode. I have the alfaobd but have not found how to disable mode.
Weirdly enough had boss tell me to turn on battery saver mode on a NISAN the other day with the scanner I never heard of it. All it does is mess with the light timing and other stuff not sure if its a thing on RAM.Battery saver mode? I habe never heard of such a thing as an on off option only an automatic truck controlled one. Not sure if it's a thing or someone's making a fool out of you.![]()
That's weird. Hmm. I thought it was an automatic thing our trucks did after the battery went down to 11v. Of all my messing around with the wytech, Alfa and maxme I've never seen it as an option. That said I've never looked for such a thing either lol.Weirdly enough had boss tell me to turn on battery saver mode on a NISAN the other day with the scanner I never heard of it. All it does is mess with the light timing and other stuff not sure if its a thing on RAM.
why can't the dealer undo what he's done or tell you how to do it?Dealer turned on battery saver mode instead of replacing battery's. Now I have new battery's and need to turn off battery saver mode. I have the alfaobd but have not found how to disable mode.
In the settings in your U Connect, ref timing for power after turn off, how longs lights stay on, etc.,. Not going into all the extra stuff like Aero modes, etc, which I do not have. Everything I have read/researched the consensus is if U leave things on, say interior light, and walk away, the default programmed seems to be 10 minutes for the accessory lighting to turn off. The bottom listing is just lights and engine off power delay: I have mine set to 5 minutes, cause say sitting awaiting for bank teller to do stuff, instead of running truck, shut down but still have my music playing.My truck seems to do all of the things listed on its own but it's a 2020 1500 DT. If I leave something on, it goes off on its own. E.g. map light, dome etc.
