Bed lights
Jkieffer
I am trying to install mopar led bed light kit. I have all the wires run up to the fuse panel. I need to tap into pin 5 which I believe has a wire already installed. Fifth wire up on bottom right. Is there anyway to verify if it is actually tan / brown stripe wire? I suspect the dealer did not activate the correct code as requested.
