Belltech 2/4 into 4/6 rear end bottoms out
nopo2491
Watsonville ca
I have the belltech kit 2/4 which i cut springs on to get to a 4/6” problem is im literally riding on bump stops in the rear so truck has no clearance whatsoever between rear axle and bump stop, will completely cutting off the bump stop cup and leaving rear end with no bump stops correct this issue? Or do i need to go with a inez rear bracket kit??
Ramcharger60
2016 crew cab sport
You will need both. If you just cut the bump stops out you will be hitting the upper control arms on the frame
Sent from my SM-N960U1 using Tapatalk
abouttobeglue
I've got a belltech 2/4 with the illicit customs bracket and airlift 1000 bags, I cut my bumpstop cups off completely. I also put switched the 4 inch regular cab springs out for the ones for a a quad cab. It's an extra coil.
hdoggie24
Huntington Beach CA
Are you saying the quad cab rear springs sit lower than the regular cab springs? If so, when you swapped to the quad springs how much did it lower you compared to the regular cab springs? couldn't we just cut a spring off the regular cab springs to achieve the same? Just curious. I have 4 in reg cab springs and wanting to go another 1/2-1" lower in the rear
MCMLXIX
Las Vegas
5.7 HEMI R/T
I think he is saying that since the quad cab is heavier, it gets an extra coil to achieve the same lowering drop of 4 inches... so when you cut it to get a 5-6 inch drop for the regular cab it helps it from bottoming it out (as much)
I had this same theory...
hdoggie24
Huntington Beach CA
I gotcha. I only plan to cut 1 coil off my regular cab springs so I think I'll be fine. Just trying to get closer to a 5"drop. Is I was going more than 5 I'd consider another option
abouttobeglue
The quad cab springs are a coil longer, raised the rear a 1/2-3/4 inch. Helped with the bottoming out for me.
drprymer
Cut the brackets completely off it will help a little
N
nopo2491
Watsonville ca
Yea i just cut them off completely today but like another member on here stated now i can really feel the upper control arms with the frame, so im guessing now for sure in gotta go with a IHC bracket kit????
Walker345
Yes and get the cut kit. The no cut kit will still bottom out in the same spot. Might as well get the control arms while your at it. Honestly you might as well get the whole Inez kit. I'll be honest here I was expecting more from my inez kit. However it's the best kit available for us. Wish I would have bought it first and saved the time money and headaches.
