Belltech bump stops
GAJetPilot
2015 Ram Lonestar
3.6L
DId you ever cut 1/2 or full coil from the rear?
"Yes I left the factory bump stops inplace. I ordered these bump stops. I might trim a little off of them. This is how the truck looks with the belltech kit installed. I am thinking about cutting one coil off the rear springs to make it more level."
GAJetPilot
2015 Ram Lonestar
3.6L
With the no cut brackets installed, will the OEM bracket that's left unused get in the way of travel?
6speed4.7
Winnipeg
Nothing ever hit on mine, but I had the Illicit no cuts on my ‘19
Finally getting around to lower my ‘23, hopefully before Christmas
I’m putting back on select parts from previous lowered trucks and some new
I’ll snap some pictures if it looks close. I think each truck is similar for fit- but have subtle tolerance and handling differences
6speed4.7
Winnipeg
Finally got into the garage this week to lower my truck
Took some pictures of how close the OEM top bracket on the rear end gets to the bottom of the frame rail using the no-cut relocation brackets
I cycled the rear end until it hit the new shorter bump stops- there is 1.25 inches between the top of the bracket and bottom of the frame rail
I’m guessing that this would be a little more than 6” drop? Riding on the bump stops it’s 17.75” to the centre of the wheel from the bottom of the fender
