R/T_Fire
- Feb 3, 2015
- 3,432
- 1,207
- Location
- Pleasant Grove
- 2011
- Hemi 5.7
So I'll be at the shop this friday with my truck up on the lift installing all my spohn links finally...
Upon inspection of my rear end and such the other day I found out I do not have a trackbar relocation bracket installed with the 2/4 drop on the truck... With the assumption its a modified drop since it pretty much sits on the bump stops in the front and has about 3/4" to 1" to the bumps in the rear (and they are Belltech bumps)
My thoughts are do I just order and bolt this one in or should I just build one that is specific to the ride height I have to keep the the trackbar/panhard bar perfectly parallel with the axle???
anyone have dimensions of the center to center bolting of the relocation bracket so I have a baseline to work from when I get under there to measure things out?
