HEMI-FI
Active Duty Air Force ( B-2 Hydraulics)
- Apr 19, 2017
- 141
- 145
- Location
- Warrensburg Mo.
- 2019
- Hemi 5.7
This is what I got accomplished on this fine Sunday morning. When I originally installed the Beltech 2/4 drop on my 2019 RCSB, I opted not to use the the front Beltech shocks due to the fact they use a a tiny 10mm shaft stud, compared to the factory 9/16” shaft stud. When you install the Beltech shocks you are forced to use the smaller, weak rubber bushings that are known for failing, not only are they smaller than the OEM they are a lot softer than the factory upper bushings. I honestly don’t think they fit the frame hole very well either, which would explain why they fail. I decided to have some 304 stainless steel bushings that are 10mm inner diameter x 9/16” outer diameter and 1.5” in length, by using this bushing it allows you to use the stronger OEM bushing.
https://photos.app.goo.gl/2atg2L9rnBq93ZS38
