Big three upgrade
loner5777j
I've got a 2012 1500 Detroit Redwing's edition, and am about to do the big three upgrade and adding an optima yellow top 27, has anyone done this yet? If so, mind shooting some photos ?
Etroze86
Grand Forks ND
I wouldn't use an optima, not worth the expense IMO and I have more returns on those than any other battery at the parts store I work at. Get a good AGM battery and it will last a lot longer than the Optima's will.
L
loner5777j
Well, I agree, but I got a brand new off the shelf optima for 120 bucks just by kinda sweet talking the manager at the local pep boys. The list on it was 275, and the girl said, oh boy that ones dusty and the only one I have, I'll let you have it for cost plus the 5 dollar core charge. Scooorrrree
Etroze86
Grand Forks ND
Yeah that's a damn good deal, try deep cycle charging it before you drop it in helps bring them back to life a bit.
autokraftgt
Hemi 6.1
That's a really good deal, but I would still return it. You can buy a better battery for $120.
I have had all colors of Optimas and none of them last and their return policy is a joke.
Like Etroze said, I'd give it a decent charge before install, and Keep the charge up, cause when the charge starts to dip, it will not recover
S
scotts2012ram
Guest
I have done the big 4 same as big 3 but I upgraded the motor to body ground will get pictures later
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I used to use Optimas, years ago. Now prefer XS Power if I need a real good battery.
S
scotts2012ram
Guest
I've used optima batteries always had good use out of then but that was before they were balt out. I'm wanting to run xs batteries but that way high for now. I get a big discount on interstate group31 battery's so that's what I'll be using for now
L
loner5777j
I had a 6volt red top in my 50 Chevy for years, at least 9 if I remember, never had a problem. I figured at the price point, I couldn't beat $ 120. I just really want to see if anyone has the big three done. Scotts2012ram, I'm definitely interested in your setup.
Boulevardvette
Im about to do the big 3 myself. I know how Im going to run the wires, but what is the best way to connect them to the battery with all the crap they have hanging off of the battery post? I dont see a way to get aftermarket terminals on there.
L
loner5777j
I bought negative and positive terminals from knukoncepts, with adapters to move the factory leads to the top of the terminal
kg93
AZ
what is the big 3 upgrade? and what would it do for my truck?
sorry for the noob question, ive never heard "big 3" in context with electrical wiring
L
loner5777j
Its using usually 1/0 gauge wiring from your alternator to your positive terminal of the battery, then 1/0 from the ground terminal to chassis and then engine ground 1/0 to frame. Helps lessen voltage drop
kg93
AZ
ahhh i got it, about how many feet of wire would i need?
L
loner5777j
All depends really on how you wanna run it, I'd say so far, just guesstimating, I used about 7 feet
Bkhsvt
Chicago IL
yellow tops are deep cycle and a lot of people buy them for every day driving, that is why they probably are getting returned as they are not a everyday starting battery. RED tops are a every day starting battery.
Boulevardvette
Could you post a pic of your connections at the battery?
L
loner5777j
I actually haven't installed yet. I'm in CT, its still snowing and cold, but when I do install, I'll definitely post photos
Etroze86
Grand Forks ND
Hardly ever sell a yellow top and its all Optima's that get returned not just one over the other. Its not a great battery like they were 10 years ago period.
VegasDragger45
Rgesse
