Bilsteins 5100's at 2.8" up front and 1" in rear
ramsport27
Anyone do this? I realize they are 2 different part numbers from front to back. This is all the lift I plan to do. It's for a 2014 sport CC 4x4. Seems better than using spacers.
WinterSoldier
Mississippi
The rear bilstein shock "allows" for an extra inch of lift to the rear. It won't "give" you an extra inch. Just a heads up!
smarsmar101
Waterford. CT
Correct, you can get the added lift out of the front with the bilstiens, but the rears just "allow" more lift. You still need spacers in the rear.
R
ramsport27
Thanks for clearing up my confusion guys. Makes sense now. :)
mjd91
San Marcos, TX
Don't be afraid of using spacers.
Many guys (including myself) run them with no problems at all.
smarsmar101
Waterford. CT
Ride quality is a little stiff.... If I have time im going to lower mine down to 2.1....
StevoTee
Agree with this. I would say it gives a 'sporty' type of ride. Definitely improves handling, but gives you more 'feel' of road imperfections.
Yup, got a steel spacer from TGC, no issues so far.
Cruizer
Ohio
2010 Sport 4x4 QC
Running 5100's at 2.8" with 1.75" rear coil spacers right now. Does stiffen up the ride but I like it that way. I didn't put Bilsteins in the rear though.
There's some before and afters in my build thread. See signature below if you want to see more pics. :)
arod412
Philadelphia
Have the same setup like cruisers... feels good because I didn't like the stock shocks...felt a little "bouncy". But my truck did develop some minor "squeaking" might be a bushing issue but I'm not experiencing any type of suspension issue. I just might wait until spring and me any my buddy will take a look at it at his shop.
I'm impresses with the bilstein shocks front and back.
Sent from my DROID RAZR using Tapatalk
R
ramsport27
Looks sick man. That's exactly what I'm going for. Definitely made my decision easy. Appreciate it! :)
Cruizer
Ohio
2010 Sport 4x4 QC
I will say that the 5100's do settle a bit. I don't have measurements, but with the 1.75" rear spacers, I definitely have rake. I personally like rake and even lifted will probably keep some. I just had to get her nose out of the dirt. Can't understand why a truck's nose would be so low.
R
ramsport27
It's all for MPG's. All you hear on truck commercials is how good the MPG's are. Which for some I guess is priority but when you buy a truck it isn't meant to get Prius numbers.
I like the fact it has some rake. I am a residential home builder so I quite often have something in the back of my truck or am pulling my covered trailer or dump trailer. As much as I don't like my front end kissing the ground I don't want it pointing to the sky either. Haha
Cruizer
Ohio
2010 Sport 4x4 QC
If you haul a lot and don't want to be nose high, might think about the air assist for the rear. I heard it's not expensive and does great at keepin' her from squatting.
R
ramsport27
That's not a bad idea. I remember looking around here and seeing a guy that had that with a 6" lift I believe. I think it was a TRX or outdoorsman can't remember the guys name though. I'll have to search around. Thanks man.
Fun250r
Could you send me a picture of this truck of you still have it. Sounds like something I might want to do with mine. Thanks!
jgruberman
EcoDiesel 3.0L
2.8 bils in front, 1" spacer in rear
ChloeBrooks
