Blinkers and hazard stopped working
N204life
OC Oregon
So now only my right blinker works when signaling either direction and same with the hazards. From what ive read allllot of people have had this problem and dodge is doing nothing to fix it so it looks like im going to have to do it. Has anyone else had this same problem, if so what part is it exactly to fix and and where would be a good place to buy it from??
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Talking about the copper connectors rusting out? The bulb isn't working at all correct?
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
being an o6 I would suspect fouled circuit boards in the tails. You can try to clean and
treat with electrostolic grease. Flasher may be suspect. If all this fails, I would recheck the volts going to tje flasher, and affected relays. Not enough volts will cause the flasher to be inoperative. Also any buld not working will also give a ''light on'' signal.
N
N204life
OC Oregon
I was reading and it people were saying a "combo switch" I just find it funny there is like 10000 complaints sent to the National Highway Safety Admin for this part going out and doge not calling it unsafe enough to have a recall
HemiBabe
DFW
did ya get it figured out?
N
N204life
OC Oregon
Not yet, seems to be working ok right now and only happens once and awhile. Will let everyone know once i get a new combo switch from autozone since i dont trust buying oem and taking the risk of the same thing happening again since someone didnt engineer it correctly the first time
Fedzilla
