blower resistor keeps going bad
balan
diesel 6.7
I have 2006 RAM, 2500 megacab, low mileage 45000, did not use much until a year ago. Blower resitor went out- blower only ran on high. dealer replaced it. 5 months later it went out again, I replaced it, now 8 months later it is out again.
Any ideas what may be causing the resistor to continue going bad?
Thanks.
LB3711
Trumbull, CT
3.6L V6
I bet the blower motor is on its way out. Moisture getting into the windings or the bearings and causing more current draw on the motor.
chedched
Madison, WI.
2019 Power Wagon
Yep motor. When I worked for Dodge, if the resistor went for the second time it was motor time.
B
balan
diesel 6.7
Thanks, looks like I will need to replace the motor. I did seem to blow well, no noise etc.. but it sounds like I need to change it.
No members online now.
crcraft
