Body lift
natewalden
Anybody know if I can install 2inch or 1.5 body lift without doing anything else like wirers steering and such
ramhunter9
P-Star Jeep Wrangler
On a body lift you will have to extend the filler neck and brake lines for sure.
IMO it would be easier to just install a 2" lift front and back. You won't need to extend anything as the stock suspension has 3" of room the extend three the factory suspension
ramhunter9
On a 1.5" body you wont have to extend anything from what I have heard from the guys that have put on the 1.25" body lifts. If you can find a 1.5' body lift anyway.
All that labor for a inch and a half ? LOL
N
natewalden
I have 2.5inch coil spacers I need a bit more room for 35 12.50 20s I have slight rub issue
ramhunter9
In that case it makes total sense . I was saying from stock adding a 1.5 ..lol
Your fine dude
N
natewalden
Well I will be seeing how hard the laybor is on a 1.25" body on my truck. I don't want a 3" body.
im just look to clear 35 12.50 20 I dont realy want a big lift so I thought if I fab a small body lift pluse the 2.5 spacers and lift blocks on rear I would be good
N
natewalden
Your fine dude
Ill have to fab the 2 inch body lift. Do you think ill be able to do that without altering sterring or anything? by the way im new to all of this, thanks for all your help man.
N
natewalden
Well if you can fab a 1.5" body up I think you will be fine. Remember you will have to raise your bumpers and if you have duel exaust you will need to raise them as well.
Its a 25 hundred no duels yet. Thanks again
N
natewalden
What about longer controll arms I know that 2.5 inch coil spacer pushed the axel towards the door im justnot sure how much
Stangshcky12
Oshkosh, WI
5.9 Cummins
Wait where are you rubbing?
I've done 35s with a level on a few 2500 now and from my experience a body lift won't help with the rubbing
If your rubbing on the lower part of the fender near the drivers door longer control arms should help
ChloeBrooks
