Body or Motor Work First???
Body or Motor work
  • Body work (bed sides and other misc)
    Votes: 1 20.0%
  • Motor work (Hughes intake/Plenum,Fastman TB)
    Votes: 4 80.0%
  • Total voters
korby05
Delta, PA
5.9 Magnum
So looking for some ideas of what to do first when my tax return comes in. I was either thinking of doing my bed sides since they have the dreaded rust bubbles on them but no holes yet. Or the other option is to do the plenum on the motor (5.9 Magnum) I have 155000 miles on her. I would swap it with a Hughes intake and the fastman tb. I have the tb already but not installed yet.
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
Mileage isn't bad, so if the engine and other running gear are ok, I would do the body work first.
Merc225hp
NA
truck
gas
Motor work first, always motor and powertrain work before looks. Do a comp test first before you start any work at all, start with jug #8 min psi is 100.
K
korby05
Delta, PA
5.9 Magnum
jug #8? how do you do the test?
Merc225hp
NA
truck
gas
Cylinder #8 pass side closest to the firewall, if you find low numbers on that jug expect the rest to follow suit on that bank.
How to do a comp test (very basic test info)
Remove the spark-plugs
Remove the fuel pump relay found in the PDB
Unhook the 12V supply to the ign coil
Install the comp test tool into cyld #8
Set the skinny pedal to WOT
Using the key turn over the motor 4 times
Record your reading from the gauge and move to the next cyld.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I would have my mechanical repairs done first. I have ordered a product called Metal Rescue to repair a couple rusty motorcycle tanks and will report how it works when I'm finished.
No members online now.
cdub5
