BOOST TIME
california
is about that time to look into boost
what do you guys reccommend so far i have procharger in mind
1. whipple supercharger
2. procharger d1sc
3. procharger d1x
4.procharer f1
5. procharger f1a
6.procharger f1a94
psi level about 14-17
what is the best options from the 6
and what fuel system can i use for this setup
will also maybe run 150 shot in 2 stages 75 offline and 75 on top
california
california
not worrying about trans since im going 4l80 working process...
CLOUDL1GHT
Lone Star State
Cummins HO
I personally prefer the Whipple. Don't have to mess with a bunch of intercooler piping and all the noise associated with a Procharger.
Have you considered doing a turbo set-up.Nitrous and a turbo work really good together
california
california
not really interested in turbo im just interested in whipple or procharger debating on which one
KLEEEEN
2015 R/T
no interest in an Eaton style s/c, what are your reasons for the above list. Just curious and good luck with the project
california
california
Thats a shame, more power per psi and no stress on the crank
i dont even think theirs a turbo kit for the 4th gen or is their besides hearing some guy did it but will not waste my money in turbo until i know is 100% guarantee it works
mondo
Columbia, Pa
2014 2wd express rcsb
Doesnt have to be a kit. If you have a performance /fab/race shop local to you, go and talk to them. You may be surprised. Ill be going turbo once i get into a ram in the next couple of months. My 06 jeep srt8 has a 76mm turbo. It wasnt a kit and Stage6 Motorsports still dont offer a kit. Ill take a turbo over a s/c anyday after driving both. Just my .02
california
california
so made up my mine on getting a whipple supercharger 2.9
now my question is
im looking into
14-15 psi what size pulley is needed?
And
17-18psi what size pulley is needed?
2010 Infantry Vet
Butler pennsylvania
Good call on the whipple. I have had twin turbos, and a kenne bell roots type blower. The whipple is definitely a better option than centrifugal for full boost off idle, and torque very early in RPM range. The twin turbo kit i had drooped after about a year, causing the oil return lines to be level with the oil pan inlet. Blew the seals out of my turbos. Turbos are mounted by exaust pipe, no frame mounted brackets. For that reason alone i wont own another turbo kit.
mondo
Columbia, Pa
Sounds like who ever did the turbo didnt do it right.....
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
My Sci-v7 turned 14psi using 3.14"/7" on a 8 rib belt. Belt slipping with higher boost is a prpblem.
Ratket
Arizona-
California residents require smog check, will you register in NV or county without smog check like Modoc County? I left California due to Libtardias sickness.
Plenty of counties in Cali still don’t require smog unless you just bought it or are selling it. Maybe he’s not gonna register it, or he’s got it plated out of state.
Subscribed-
Curious how this goes. Keep us posted
The guys who make the monitour ram offer or have a lot, and I wanna rapp or something like that makes a kit as well. Just get your hands on a TRX rebel motor as soon as they start making them and ur all set.
