mwardncsu
I posted this over in the Lifted sub-forum, but it may be better here...
just finally finished the install of a RC 3” suspension Level/lift (new springs / shocks on front, new shocks and block on rear) on a 2004 RAM 1500 single cab, 6.5’ bed with RWD.
Had Cooper Discoverer XLT 285/75R17 tires installed (previous were 265/70R17) on existing wheels and a alignment performed.
The truck is pulling to left a fair bit so I’ll need them to relook at the alignment - but even worse at 45 mpg there is a pronounced and sustained "bounce" which I believe is coming from the rear. Below 45 it seems ok and once I get over 50 mph it settles out again (haven’t gotten it above 55 yet to see if it occurs again at higher speeds).
I’ve seen some reference that perhaps the tires may be a little over inflated, or others have described something similar at 45 mph and said new shocks solved it - but I’ve got new shocks via the kit
Anyone experience anything like this and have suggestions?
