Kater_tot3
I’m not super savvy on this truck, it’s got way to many electrical components and it’s my husbands work truck, not mine.
A few weeks ago left rear caliper seized. Replaced left caliper, rotor and both rear brake pads. Immediately the pedal was super spongy, no brakes until almost on the floor. We re bled again, same thing. We gravity bled, same thing. Replaced right caliper and no change. Pressure bled with mechanic and nothing. We were about to replace master and booster but after pinching lines mechanic isn’t sure that’s it. He’s narrowed it down to the ABS.
Mechanic went ahead and called the dealer, dealer who also thinks it’s something in the ABS and said they have to actually unplug the computer to fix it, reset to factory programming and then re install, as well as reset aftermarket programmer. Apparently it’s an issue for this specific year?
Has anyone dealt with this? We’ve been trying to fix this issue for almost a month and the truck still doesn’t have brakes, but I’m so wary of dealerships and their $125/hr labor. I can’t find anything online if someone having a similar issue.
