Brake issues
Shane_o_ca
BC, Canada
5.9 magnum
So I was taking apart the front brakes on my 01 Ram 2500. They were pretty rusty and it was sticking a bit. I discovered the caliper bolt was stuck to the sleeve. Is it necessary for the bolt to slide in the sleeve? Should I be replacing it as well?
There were other issues with the brakes as well, but I think I have it figured out.
Merc225hp
NA
truck
gas
They don't have to but it's nice if they do, some are pinned in to limit movement. If you are close to Sicamous, BC I have a set here you can have they are for the 8800 gvw brakes.
Shane_o_ca
Shane_o_ca
BC, Canada
5.9 magnum
Good to know, thanks. I'd take you up on the offer but I'm in the lower mainland.
Cheers
Raadz
