If the tires break loose during braking, especially during an emergency maneuver, the ABS is supposed to kick on. That is LITERALLY the only thing that system is designed to do. In what universe would it make sense for them to be programmed NOT to come on if slamming the brakes on in an emergency situation? Can you look on the online manual and share with me the page you think this alleged system is on?
No joke, go read your manual. If I’m lying, I’m dying. The systems that impact not being able to initiate ABS on dry pavement are called Brake Assist System and Electronic Brake Force Distribution.
If tires slipping in a stop is bad, and ABS only activates AFTER tires slip, you think they wouldn’t start working on ways to keep them from slipping in the first place?
