Brake rotors for 1997 Ram 1500 2wd
Slspacek
maryland
5.2L
Does anyone know if rotors with the abs ring will fit/work on my 1997 Ram 1500 which has only rear abs? I am looking for rotors and having a hell of a time finding ones with out the ring. Can or should the ring be removed? Thank you for your time.
Nealuss
5.2L 318
They should fit no problem. The ring shouldn't interfere with anything but you can always knock it off if it makes you feel better. A couple minutes with a torch usually does the trick.
