Build a box for under the seat
korby05
Delta, PA
5.9 Magnum
I wanna put a sub in but I have the fold flat floor. I was looking at it the other night and it looks like I may be able to remove the short side of the floor to add a sub. I don't really wanna buy a fox box because that would require removing the whole floor and I actually use it from time to time.
Now the question is has anybody built a box using the current holes and either kept the floor or removed one section?
Thanks in advance
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I thought fox box had a single side box as well.
quietpeen
2021 TRX
Hellcat
the only way you will really get the proper air space is to do a custom fiberglass bottom, but even then i think you have to use the larger side. Another option is to build a center console box
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Might be enough room in there for the Bazooka tubes if they still make em, or that small sub Graygoose just picked up.
