Bump stops
SILVER_BULLET
Anyone have part numbers for the front and rear bump stops that come with the belltech lowering kit?
TylerB
FL
The 2" front stops are #4923.
SILVER_BULLET
SILVER_BULLET
I think I'm going to go a little lower then 2" now you think they'll still work ok?
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
The guy at Firestone said my truck was already sitting on the front bump stops. I don't see how that's possible.
TylerB
FL
No, you'll have use something shorter up front. What I did was move the 2" #4923 to the rears and bought some Belltech #4922 for the front.
SILVER_BULLET
SILVER_BULLET
i think i remember someone else saying that somewhere and that belltech replied to them saying the kit was supposed to be that way but not sure why
No, you'll have use something shorter up front. What I did moved the 2" #4923 to the rears and bought some Belltech #4922 for the front.
ok cool ill end up doing that also i want to try and get mine as low as possible before i start hitting stuff so i think a little more then 3/5 should be possible right
Lhemi
OKC OK
Wow that was weird. So do I need shorter bump stops?
BlkRamRt
SoCal
HEMI 5.7
No thats how belltech designed their kit. Unless you cut your springs. You will need shorter bump stops.
nopo2491
Watsonville ca
If your at 3/5 or lower and u want to go with the 2" belltech bump stops in the rear do people cut off the factory bump stop cup on the rear like you do in the front?
My belltech kit came with front and rear bump stops, the front work great but being that i cut springs my rears are hitting im actually riding on them so if i order another set of front ones and put it on the rear will this work, it sucks riding on them!!! just wanna make sure i need to cut bumpstop bracket or cup before i start doing it, and is there a whole there to screw in another one like there is in the front or will i have to drill???
SILVER_BULLET
SILVER_BULLET
hmm never thought about that i have never looked to see if there is a hole there or not either
DERJ
Austin
2014 R/T
How did you mount the #4923s in the rear?
Did you grind off the bump stop cup?
Any pics? :roflbow:
Just trying to understand where to bolt the #4923 since it does not press in like the stock rear bump stop and I can't see how to tighten the bolt as the frame is closed off above it.
S
scotts2012ram
Guest
How does it not ride like crap with the dump stops lIke half inch off the control arms. I live in Mississippi I'd probably beet it off the frame in a week
sicmadek
Banned
ponchatoula,la
2014 express qc
I have the belltech 2/4 withstock shocks and my front bumpstops have 1/2"-3/4"clearance above the control arms. My rears have black on them showing that they have been hitting and my truck really is t that low.
RobHinton
2013 EXPRESS
HEMI 5.7
Anyone have any info on how to mount the bumpstops that were intended for the front onto the back? As always your advice and help is much appreciated.
Raadz
