Bumper Conversion
theylovenoodles
Jacksonville, FL
Hey So I Have A 2015 Ram 1500 Express, And Personally I Like The Way The 2012 Ram 1500 Sport Bumper Looks, Would I Be Able To Just Put The Bumper On Or Do I Need Additional Hardware, And I Know I Would Need The New Foglight Bracket For It.
BJSwizzle
Edmonton Alberta Canada
2019 1500 Sport
5.7L
If you have a 2015, you can use a sport bumper set up from 2013-current classics, anything before that, the grille is shaped different and will not fit. It’s not that hard to do, uses same mounts, just need crash bar and plastic piece that the fog lights mount to, did the conversion last spring
theylovenoodles
theylovenoodles
Jacksonville, FL
Thank You Very Much
2013 & newer Sport front bumper uses the same grill & fenders as the chrome bumper does
2009 - 2012 front is different shaped
2009 front sport bumper - look at the bottom of the grille in the corners & the top of the grille emblem, they are more or less squared off
look at the same places on a 2016 bumper, those corners are cut off
Ftank
