Buying Used - Need Guidance/ Advice
bgettel
Maryland
N/A
N/A
Hello All,
New member here. I will soon be buying another vehicle and am considering getting a truck. Long time Ford fan here but have never owned a Ford (or any American-made) truck.
I want a crew cab 4x4. I don't want to spend more than 10 - 15K, so I'm forced into looking for high-mileage trucks in decent shape. I may or may not buy from a dealer. I'm aware that every mfg has or has had issues with rust and such. I'm more concerned about reliability as I don't know these trucks at all.
  • What engines have a good reputation in general?
  • Is there a certain engine(s) that is/are more reliable than others?
  • What do I look out for w/regard to determining if an engine is in good shape?
And pretty much the same as above for the 4x4 drive train. Note that I won't be doing any offroading and very little towing, etc. I mainly want to be able to move around in the snow when I need to.
Thanks in advance.
BG
Rebel4Mo
Billings,Mt.
Your price range is most likely limit you to well used trucks with high mileage.
I bet many will need some work done if not already done.
Even when I was looking to replace my 2001 Dodge Ram 2500 5.9 Cummins 4x4 with a newer used truck in the price range of 40K-50k many had high mileage and seemed over priced.
I ended up buying a new Ford F250 XLT.
I sold my 2001 with 196k kiles for 11K about 4 months ago.It twas on its s second transmission which was acting up and it also needed some front end work.
First transmission was replaced at 164K miles.
Tray Burge
On the porch
Depends on what you want a truck for?
Personally, I only wanted a hot rod, muscle truck just to have fun. My wife always complains it wasn't the truck she wanted (she had zero input) and she can't haul anything in it.
I always tell her, you're correct, it's the truck "I" wanted and it hauls ass. lol
suicideking
Riverside, CA
If you're not experienced in checking out used vehicles, I would want to take it to a mechanic for inspection. Just tell the mechanic your situation, and that you want it checked out. For starters, you should check the engine, trans, frame (check for rust), brakes, suspension.
I didn't follow the above advice when I bought a used 2011 F150 with 60K miles. It needed a new engine at 65K miles, so I was out an extra $7500. Speculation was that the PO didn't get oil changes often enough, or was towing a load too heavy for the truck to handle.
You could get a warranty, but again, buyer beware. Lot's of warranty companies will tell you 'everything' is covered until you start submitting claims and find out nothing is covered.
CanuckRam1313
Ontario Canada
2023 Warlock
KAKA
