Bypass AC compressor
nickykinsman
Ontario
2021 Dodge Ram Classic Warlock 5.7 V8- Looking for what size Serpentine belt to get to bypass Ac Compressor. Can not get an answer anywhere!
tron67j
Maryland
One thing you could do is cut current belt, then wind it around the pulley of each remaining unit and trim down until you get size you need. Be sure to move tensioner all the way to no tension first to give you the adjustment you need to tighten. Good luck.
N
nickykinsman
Ontario
Thank you! He decided to get a clutch kit instead. Ordered the wrong one, and new literally just came so hopefully it’ll work!
