Cab lights
Randy6666
Va
6.7 diesel
2020 limited w/power wagon option. Would like to add clearance lights.
What do you all think are the best ones for looks and install.
Tks
NorthStar1
Rosenberg, TX
2020 Ram 1500 Big Horn/Lone Star 4x2 Crew
Hemi 5.7 eTorque
The best are ones that never leak...and I never had a 2500 or 3500 that didn’t eventually leak and/or corrode around the holes where the wires penetrated the roof. If it were me, I wouldn’t ruin the integrity of a drip free roof but if you decide to go for it there are kits from Mopar. There are aftermarket magnetic wireless units but I don’t know if they are quality or dependable.
The part numbers below will give you some info for researching pricing.
Cab Lamp - Mopar (68362179AE)
Snap In Nut - Mopar (6509432AA)
Header Wiring - Mopar (52112533AD)
R
Randy6666
Va
6.7 diesel
Thanks for the reply northstar1
Agree I am not totally sure i will do it. Old 07 2500 had them
From factory. Liked the look but don’t want leaky roof either.
Tks
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
I would only add them if they were required. I've owned a couple older trucks that came with them from the factory, and they always ended up leaking at some point. Usually it was from the gasket(s) drying out and cracking. It's easy enough to change a gasket, but damage can occur if you don't catch it right away. Looks are subjective, and if you like the look of having clearance lights, more power to you.:favorites13:
Personally I prefer a clean roof line.
farmallboy
Croton
6.4 hemi
LOVE the cab lights.
I've owned 4 trucks and 2 of them had lights installed. Never had an issue. Quality parts and either a long careful install or get a reputable instal place. Shouldn't be an issue.
Badger 13
North Idaho
2013 Dodge Ram 1500
I'm in the yes camp on cab lights. I have had 2 trucks that I was able to order them on, and 3 trucks of mine that I added them to. Also installed them on several other trucks over the years and never had any issues with any of them. The hardest part is drilling that first hole.....
NorthStar1
Rosenberg, TX
Hemi 5.7 eTorque
A lot depends upon how long one plans to keep the truck. Most only keep a vehicle for a couple to a few years and then trade for the next new whizbang offered by Ram. However, if you plan to keep it longer than six to eight years - and you live in an area known for corrosion - them you could be a candidate for leaking clearance lights.
As stated above, usually it is the gaskets that go first so vigilant maintenance/replacement of the gaskets and you may it have any problems regardless of how long you own it. I could never time it just right to replace gaskets before one started leaking so err on the conservative side as they are cheap. And yes, they look great when lit up and not leaking.
P.S. I'm not a fan of sunroofs either...due to potential for leaking.
John KIOhio
Ohio
Tks
I had my dealer put them on my 2016 3500 Mega. Factory lights, $226.31 installed. Wiring harness is already there. I could have done it but they do it all the time and it took 1-2 hours.
horace33
MN
97 dodge 18LARAMIE
I have 79 I added cab lights to 40 yrs ago, no leak & a 97 10 yrs ago no leak. 79 off the shelf 97 off salvage Good luck "I think" it gives them the truck look
