Got interrupted posting...
Well they do the exact same thing, lock the axles together like a spool does. I guess the solenoid on an E-locker could fail. But not that likely on either.
The ARB has a proven record in off-road applications, but they've found success on the drag strip as well. I had a WaveTrack limited slip before this. More similar to the Mopar unit, but much stronger. It didn't have the bind issue the Detroit/Eaton lockers had in turns. It lasted a couple of years. But I blew it apart and it turned into a spool. So I obviously had too much power for it. The guy that built my 9" recommended the ARB. So far, so good, but I've not had a chance to make more than a half dozen passes with it. But last time I had my Toyo street tires on the Jeep, and I was surprised it hooked solid. I do have the Mopar unit for my Ram, but haven't gotten to installing it yet.
wink
