Can I fit 35x12.50s on my 2019 Ram 1500 laramie 4x4 with a 2 inch level?
Sam Strange
Needing new tires, and I want to get some beefier tires I am curious to see if it is possible to fit 35s on my ram 1500 with a 2-inch leveling kit from Ready lift. I plan to use the stock wheels that came with the vehicle. Has anyone accomplished this?
TestPilot57
Vermont
Depends on the actual tire.
I have 35x12.50s on my '20 with a 5" lift and 1/2" spacers* and still get a small amount of rubbing when turned all the way to the right.
*I might be able to get away without the spacers, but there is just about 1/2" clearance between the inside of the tire and the suspension.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Quick answer yes. But It would be easier accomplished with an aftermarket wheel.
Bstern36
Orange County
I have the air ride with the 2.5 leveling kit. I just put 35x12.5r22 stock wheel and they fit.
Dylan Campbell
Phoenix AZ
I am on 2" coils in the front and 1.5" springs in the back and have a ton of room on 33's. I feel like 35's would fit my setup well, and plan to to that route after these are toast. This photo was before the 1.5" coil springs in the rear. I have also since gone to aftermarket wheels with 0 offset and that made a huge differnece in clearance between the tire and control arm. Not that there was an issue before.
Warlock1
Buckeye, AZ
Eco Diesel
35x12.50 with a 2.5 inch lift. I had to remove the plastic mudflap piece.
JVs Ram Limited
I have a '19 1500 Limited with the Off Road pkg (1"lift) and wasn't aware you could put a leveling kit on. I thought the air ride automatically leveled. Can you send me a link to this kit?
Bstern36
Orange County
