CANBUS HID question..How hot is too hot
posttal
Cleveland , Ohio
2011 and 2013 Laramie
I've been fooling with putting HID headlights in my 2011 Ram for a few weeks now.. first I did the install to find they flickered and went out...then I installed a relay harness to power them on a separate line just to see they did the same....and now the CANBUS canceler/resistor..... Well the Resistor did the trick and the HID's stay on with no flicker..BUT..the resistor/canceler gets pretty damn hot ......so how hot is normal ? I haven't actually put the headlight assembly back in the truck yet as I'm running them with the truck running..to make sure they're ok before installing totally as you can see in the picture..So as I wait a while to make sure they stay on I'm also keeping an eye on the heat.
xrsman
Ontario
3.0 Ecodiesel
They'll get wicked hot, like burn your hand hot.
posttal
posttal
Cleveland , Ohio
Hmm...Well I guess that's a good thing then....I just put the other side together and have them both on...gonna let them sit on while running for a while before putting the grill and everything back together....I'm getting tired of taking this apart
xrsman
Ontario
3.0 Ecodiesel
Lol yep I've had my front end apart about 20 times. (not kidding) I'm getting better at it than I should be lol!
Sent from my SM-G920W8 using Tapatalk
