Telewrangler
Hi,
I have a 2004 Ram 1500 5.7 two wheel drive. It has mainly been our extra truck / weekend driver as I was a plumber and pretty much always drove my work van all week for years. The Ram has 107,000 miles on it.
The lightning bolt will flash as you are driving. It will lose all power for a second or two then resume like nothing happened. The lightning bolt on the instrument panel will then disappear. It will show no codes. Several people said that the throttle body is most likely the problem. I replaced it and nothing happened. I replaced the accelerator position switch, the second thing that they told me, and nothing happened.
I took it to the Dodge dealership. They could not find anything wrong or any codes. They unhooked the battery and drained all of the power and did a computer reset.... It seemed to work, I drove it for another few weeks and it has been fine. I thought we were good to go, but was I wrong! ... We went on vacation this week, four hours away from home from NC to VA to Kerr Lake. Now, it is doing it again, but even worse. Now, when you start it,,,,,, it revs to 1500 rpms and the accelerator pedal does not work. You turn the engine off and it may start and drive normally for a while. Then when you go to start it again the engine will turn over but it will not start at all. If you let it sit for a few minutes, it will finally work okay again. I'm thinking that it is going to leave us stranded here 200 miles from home..... Nobody, not one of the Dodge techs in Shallotte NC, could find anything wrong with it or repair it..... The truck will not produce codes since it is an intermittent problem.
Any suggestions would be great! .... How can something be repaired if nobody knows what to repair?
I would appreciate your help! ... We need to drive this truck back home somehow.
Thanks!
Thanks!
