casting number
tloh
columbus, ga
5.9 cummins
Trying to find the casting number on my old truck to see if its a 53 or not, but cant find the casting number anywhere where pics are showing it. driver side under injection pump by where the oilpan bolts, next to the big piece of wiring loom that mounted on the engine correct? even looked under the oil filter on passenger side and nothing. any help of other locations to look?
Fast69Mopar
I have found the number in two places. One is just below the VP44 injection pump, above the oil pan, on the block and you can see it from underneath the truck looking up towards the VP44. I have also found the #53 casting number while changing the oil on these truck. The casting number was just behind the oil filter below the oil cooler. Hope this helps.
