Catch can —-> Max Care Warranty
McBroom
Denison Tx
Hemi 6.4L
Does anybody know if installing a Catch Can will in anyway violate the Max Care lifetime warranty?
No affect on the MLW
Blue Streak Pearl off-road package
William Hastings
Aston, PA
I have the max care, but 8yr 75k for now. I dont do many miles per year. Was thinking about upgrading to lifetime at some point
craigsez
Novascotia,Canada
Dealer/manufacture has to prove that your mod caused the failure,its up to them to prove it....There lays the issue,they can hold up the process for ever and in the long run cost you..
One dealer will say its fine and another will say its bad...Get it in writeing from your dealer that its fine and will not void..
My dealer said we don't care what you install as long as you realize if the part you installed caused the issue then its on you..Parts guy even went as far to tell me what he installed on his car that he bought there new..
Kinetic
As previously mentioned, this doesn't pertain to aftermarket warranties, only the factory warranty.
Factory
Irwin
I Supply Amsoil oil
& filter , my dealer does mine every 5,000 miles and drains my catch can , they laughed at this post -smh
chrisbh17
I Supply Amsoil oil
The problem is when the rubber hits the road, will they be laughing at your catch can or using it as an excuse to not fix your worn out camshaft and/or lifters?
Rutland
To be honest, these are questions for your dealer. Opinions here are all conjecture.
I have had maxcare on two modded jeeps and this truck. The only way it voids the warranty is if the installed part wears out a component. Then only that part is not covered.
Like putting on a lift and the bushings wear out. Bushings wouldn’t be covered.
Pull Ya
Cedar Creek, Tx
IMHO if your going to add mod's I think you should have a little "stash" somewhere just in case a repair comes out of your pocket. The law may be great but by the time the team of lawyers get through with the case and all the appeals and final litigation is completed your truck will be close to an classic. It sure would sound great to tell someone, " Boy I showed them, it only cost me 50k to win a suit where the repair would have cost 2k". Maybe you'll win attorney fees, but probably not all of them. And the WORST part is you have to trust an attorney.
Jay
BWL
Embrace the skeptisism
BC Canada
If you have the lifetime warranty why would you care about having a catch can or even using better oil/filters?
chrisbh17
I like making sure my vehicles are taken care of, regardless of warranties.
I have MaxCare Lifetime myself, but why would I not do everything I can to make sure the truck is in good condition, at minimum it could save me the hassle of having to get that warranty to actually cover something 7+ years from now.
BWL
BC Canada
Fair enough. Just sounds like you're risking non coverage if something does fail due to defect that the catch can would not have prevented like lifter failure. Might get covered in the end, but it could take years to get reimbursed if they deny you.
misfit77
Imagine us with remote oil filters?
If need be I can return the crank case ventilation and oil filter back to stock in less than an hour.
God help me if I have to do this on the side of the road before the tow truck comes.
McBroom
Denison Tx
Hemi 6.4L
Can i get that in writing lol
Sent from my Nexus 6P using Tapatalk
Ask the service manager for a letter and they can provide it.
chrisbh17
Catch can is one thing, but using a non-Mopar oil filter is just plain annoying. The fact they could use a better filter as a reason to deny coverage really ticks me off and actually makes me unhappy with my MaxCare purchase.
Still question if they can void a MaxCare contract while you're under the factory warranty, if they see a non-Mopar part on the vehicle.
BWL
BC Canada
I'd be less concerned about the better filters especially bigger brands like fram who have taken manufacturers to court themselves for having coverage denied for using their product because they're a big company and their product voiding warranties would cost them a fortune in lost revenue.
Ramnewbie
I don't know the answer but they make notes everytime you're truck is at dealer. So if they notate that you were using non Mopar filters or have an occ or noticed that you're pcm had been switched and I've heard they can also see how many times you're pcm has been accessed as far as programing or tuning. So just putting back to stock may not be a valuable answer in the end. It goes back to if you're dealer wants to be a ****.
Sent from my XT1650 using Tapatalk
Kukailimoku
Honolulu
I get it what you're saying about the pcm access being detectable, but a catch can as the OP shouldn't have an affect on any logs, would it?
Would the engine sense/know/log that it wasn't ingesting all that krap blow back?
Ramnewbie
What I was getting at was dealer would notate pvc system modification, then sometime down the road they could use that as a possible reason for something failing, maybe throttle body or plenum gasket. Which in reality the occ should help both if it had any effect.
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
I wouldn’t be too concerned about a catch can. But as someone else said, ask your dealer. When I had the dealer do the first oil change on my SP the tech actually emptied mine and wiped it down lol. So many guys put these on Hemis I think a lot of service departments are really starting to get used to seeing them. Prob would have to be a really **** department and a pissed off Chrysler case manager to deny a warranty claim because of a catch can. But stranger things have happened.
TMFMK
