CEL codes
Allikanbe
VA
My CEL light came on yesterday on my 2002 Ram V8 auto. The truck has 127k miles on it and this is the first time in 4 years that anything has been wrong. I took the truck to Advance Auto for a scan and the codes were:
P000 - Knock sensor
P1740 - Torque Converter solenoid
78 - base brake system
OK, where to start? I've owned the truck for about 4 years. I'm sure the trans fluid and filter need changed. Eveything else about the truck is great. There are no issues when driving. I searched on this forum and found some posts about the torque converter. They don't look good.
THere is no knocking, so I'm not sure what that is about.
A
Allikanbe
VA
actually, it's a 2001. I used my scanner today and cleared the CEL. Now, wait for it to light up again.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
I would buy a replacement Mopar knock sensor, just in the event you end up needing it to have it handy.
When you do the trans fluid and filter, delete the check valve, around 160-200k miles they start to clog, some trucks even sooner. Also look at replacing the two sensors in the trans while the pan is off, they run about $120 I believe. Could be the cause for the CEL for Torque converter lockup sensor
Has been a while so please report back if your CEL came back what youve done to fix the problem.
A
Allikanbe
VA
Thank you. I haven't fixed it yet. I plan to start next week. Those transmission sensors look like no fun.
A
Allikanbe
VA
Got the codes read again at a dlfferent auto store. ABS and ECM. WTF?
