center dash removal?
iam_canadian22
northern ontario
how do I remove the center dash panel? I want to relocate my led bar switch to this panel for easier access, I also have the center console shifter if that changes anything with the removal process
ramenthusiast
Banned
W. Palm Beach, FL
2012 Crew Cab Sport
It's got a Hemi!
Good instructions, but it is not necessary to remove the shifter insert,cupholders just to remove the lower panel. Once you remove the chrome trim ring you can remove the outer panel without touching the insert.
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Hows the trim ring connected? Just clips?
Yeah lots of clips.
Just gotta pry up gently in one area at a time and work your way around.
Be firm but not forceful... it will come off.
