Ceramic spray problem
Bulldawg59
Retired USN
TN
I treated my truck today and got over spray on my windshield and it left a film. What's the best way to clean it? Thanks for any help
buddy guy
alberta
Chemical removal Although ceramic coating have very good chemical resistance for most chemicals, they are not very strong against alkaline products. It is not clear if these are capable of removing the entire product, but they are know to damage the surface layer and negatively effecting their performance. It should be noted that a product that is chemical enough to remove a ceramic coating, can be strong enough to damage the paintwork underneath as well. Claying Claying alone is not likely to be enough, but it should have an effect on the coating. Especially when the coating is a bit worn, it should be possible to remove a large part of the product from the surface. Polishing It is widely believed that polishing is the most trusted way to remove a ceramic coating from the surface. This will also help to prepare the surface for the new product and remove certain imperfections.
Read the original article at: https://www.detailingwiki.org/protection/remove-ceramic-coating/
my first thought actually was wondering if you used a razor blade if it could remove it?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
What ceramic spray? Was it Adam’s was it an actual ceramic or just ceramic infused product.
Steel wool will surely remove it
Bulldawg59
Bulldawg59
Retired USN
TN
I looked it up online again it is a silica based product.
Bulldawg59
Bulldawg59
Retired USN
TN
Thanks for the replies. I ordered some Chemical Guys wash that should remove it.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Spray some on a microfiber and rub it in. It should reactivate the si02 and you can wipe it off will a clean towel
Greif
WI
What about just coating the glass, i see some ceramic coating recomened it.
averageguy
Belleville Mi
hemi
I have removed a lot of paint overspray, sticker residue, and paint marker off of windows with a razor blade spray it with Windex as a lubricant and scrape.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
How did you make out?
Bulldawg59
Bulldawg59
Retired USN
TN
Washed the windshield with Dawn and the film is gone but I still have great sheeting.
joshhhh
