ModestoRebel209
I have a 16 Rebel with the regular usb and SD card reader, would I be able to switch it for the new Hub with the usb C???
+1 on the Anker. Good stuff. Own several of them.I'm guessing you could but the only thing you'll gain is the shape of the plug will be USB-C instead of USB-A
There's no speed advantage of the USB-C port or high power charging capabilities.
Buy yourself some Anker Type C Charger Premium Nylon USB Cable , USB A to Type C Charging Cable
https://www.amazon.com/dp/B07DC5PPFV/
They work great for streaming music whether is via radio media or Android Auto and they hold up lots of use. I have two plugged in at all times in my truck, one in a charger the other for the AA port.
It's not as simple as just using a USB C Port that has to be the right charging technology.
Just for an example Samsung uses adaptive charge which is a version of Quick Charge then you'll have the phone such as Google pixel for example that uses power delivery charging.
Then crApple with lighting charge, advice is a modified version of power delivery.
The newer Quick Charge version 5 is cross-compatible with power delivery charging but not quite at as high an amperage so using the proprietary power delivery charger you'll get a higher amperage meaning a faster charge
all they've done is brought us back to the old battle between VHS and betamax or Android versus POS crApple products
Sent from my Pixel 5 using Tapatalk
