Changing spark plugs 03 5.7
Farmer888
ontario
Have no Idea when the plugs were changed last but I have put 50,000 kms on (31,000 miles) since getting the truck and haven't changed them. Still runs amazing but I'm sure it's well past time to change them out. Planning on the copper champion plugs nothing different. But wondering if there's anything I need to know as far as special tools/ wrenches or steps to follow etc? Reaching the back ones on the driver side looks a bit difficult.
ST-8
Nothing a couple extensions can’t get to
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Yep my tech uses a short wobble with an extension to get the back plugs out. Farmer, don't make the mistake I made in my 03 5.7. Stay with OEM spec plugs.
Karlsweg
SW Florida
Make sure you don’t drop the new plugs into the hole or the gap could be closed! Use a spark plug socket or a piece of fuel hose that will allow you to screw the plug in. Plan on loosing some knuckle skin lol.
HemiLonestar
Navy Badge Coast Guard
MD
3/8" drive ratchet, plug socket with rubber insert, varying length extensions and PATIENCE lol, especially on the rear two driver's side cylinders. The passenger side is easy, especially once you pull the air intake out of the way.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Generally for every .001" over .044 is equal to 2000 miles of use. This tool is all you need after coils are removed.
F
Farmer888
ontario
ok thanks guys, Truck has a k&n intake so lots of room on passenger side no air box in the way. Seems easy enough of a job to do.
Redtruck-VA
Virginia
A thick towel folded and layed over the radiator support, then I stand on a low box and just lay over onto the engine where I can reach everything. And if you ever replace the brake booster with a hydroboost unit you'll have even more room.
