Check Engine - Coolant Sensor
72rocket
V8 5.9L
Check engine light is on and after getting tested it came up that the coolant sensor was bad. Replaced that and light remained on. Disconnected negative terminal and still nothing. Got tested again at AZ and it still shows the same issue. Is there something I am missing on this?
1996 Ram 1500 5.9 V8
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
There are two sensors for coolant. Did they replace the right one? the single wire sensor is for the cluster, the other is the PCM. They're right next to eachother.
