Check those chains
runamuck
Air Force
dfw
6.7 dsl
can the sparks really travel far enough from the road to start a fire. I have seen this from trains because weeds and grass often grow right up to the tracks. but yes, good idea to dbl. check everything before getting on the road. I also do a walk-around at every stop just to make sure all is good.
Ramagain
Good point. I always keep mine off the ground but never really thought about the sparks causing a wildfire.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
The State owned roads are cut quite often during the hot months, they do that mostly because of Catalytic Converters
Matches burn at 600°-800°F
Cats burn at 1,200 to 1,600 degrees F.
If you drive out to the local Park, the grass along the road is close to knee high
