Checking Torqueflite fluid level?
Vaughn4380
3.6 Pentastar
Sorry if this is a repeat, I searched and couldn't find anything. How do you check the fluid level on the new torqueflite transmissions? I don't see a dipstick anywhere. Truck is a 2013 4x4 slt with the 3.6 if that helps.
AirborneSilva
San Antonio, TX
2013 Sport
That's just it, you don't. It's suppose to be life time fluid and unless you have a leak you shouldn't lose fluid.
scHemi
2009 RAM SLT Crew
It's made by ZF. none of their transmissions have dip sticks and are sealed from the factory never change fluid which is *********. Change it every 50k or regular intervals
deathwarden5
2013 Ram 1500 Sport CC
Hemi 5.7 8A
The check/fill plug is on the right side of the transmission, near the rear, just above the oil pan. The oil temp HAS to be between 40-50C.
There is no real reason to have to check the oil. And a ZF will flag faults related to low oil level way before you would notice a problem.
V
Vaughn4380
3.6 Pentastar
Cool, thanks, any info about these transmissions online? I actually did have a leak that the dealership fixed under warranty. So I figured I should check the level "just to be sure".
toofart
QC Canada
Hemi 8 spd
What a crock of crow. I hate this "sealed for life, until it breaks" crap. Right up there with non-greasable tie rod ends and ball joints.
joshhhh
