Dan Topp
- Aug 14, 2019
- 794
- 1,336
- Location
- Jefferson Wisconsin
- 2019
- 5.7
Always love a bigger filter.ThanksI used the larger filter from the 2010's. I have tried the ziploc bag, still makes a mess since I have to turn the filter after breaking it loose. The container doesn't work well due to how close the k-frame or steering rack is. I usually put grocery bags over the k-frame to catch drips. I mainly don't want oil between there and the steering rack which builds up gunk. Filter relocation introduces a lot of new potential leak paths.
I took a piece of house gutter trimmed down the sides its about 3' long I never spill a dropRam couldn't of put the oil filter in a worse position than they did really. It's like they wanted to see how dirty one could get just trying to remove that oil filter. I bet many of them laugh at the complaints they have gotten throughout the years having the worse placement probably ever.
With that said having a oil change come up I wanted to see your recommended method of not spilling a single drop. I did get the Fumoto drain valve and am looking forward to that. From what I have seen there is a couple methods as far as removing that dreaded filter goes.
1. A couple quart ziplock baggies. Simply first loosen filter then put baggie around and loosen more so oil starts draining in baggie. Seems this is still kind of a PITA because hard to angle that filter at all and still seems to spill a little oil?
2. From what I can see best method is that XL Oil Udder. Have any of you used that for our particular 4th gen RAM's and does that truly do the trick?
