Burn2k12Ram
- May 17, 2022
- 582
- 845
- Location
- Reno, Nevada
- 2012
- Hemi 5.7
Ram couldn't of put the oil filter in a worse position than they did really. It's like they wanted to see how dirty one could get just trying to remove that oil filter. I bet many of them laugh at the complaints they have gotten throughout the years having the worse placement probably ever.
With that said having a oil change come up I wanted to see your recommended method of not spilling a single drop. I did get the Fumoto drain valve and am looking forward to that. From what I have seen there is a couple methods as far as removing that dreaded filter goes.
1. A couple quart ziplock baggies. Simply first loosen filter then put baggie around and loosen more so oil starts draining in baggie. Seems this is still kind of a PITA because hard to angle that filter at all and still seems to spill a little oil?
2. From what I can see best method is that XL Oil Udder. Have any of you used that for our particular 4th gen RAM's and does that truly do the trick?
