dentom052
Is there a special way to clear TRANSMISSION codes? Or do you just use a generic OBD2 reader? My 46RE transmission is currently in the limp mode (3rd gear only).
I just purchased the truck recently, and suspected transmission needed to be removed and overhauled. I am a transmission mechanic but don't normally work on Chrysler products.
Transmission took off in 3rd gear and lockup worked fine. Shifts manually ok but no overdrive.
Upon disassembly, I found 3rd clutch plates worn almost to metal, but someone replaced filter and oil so not much debris in the pan. So It needed to be overhauled.
I understand that when a trans code is set, it takes off in 3rd gear. Just don't know what the procedure is to clear it when I reinstall the transmission.
Thanks, Dennis
Thanks, Dennis
