Closed 1500 tow hooks
Bartlert
Edmonton Alberta
Hey everyone new member. Just wanted to see if anyone has seen closed front tow hooks for the 1500 or is it just something I will have to make.
Thanks everyone
Nate4x4
The Vehicle Reader
ON, Canada
5.7L Hemi 4x4
Thanks everyone
Welcome, is this what you are referring to?
Bartlert
Bartlert
Edmonton Alberta
Ya more like that. Just so I can put a recovery ring around it instead of trying to hook a rope loop to it. Where did you find that one?
kad
Hudson Valley, NY
5.7L HEMI
I think he's looking for the solid loop style used on the 4th Gen HD trucks or the 5th Gen 1500's. I've not seen them for the 4th Gens.
-K
crazykid1994
Rebel has closed hooks. Unfortunately they aren’t easy to obtain (you may have to go to the dealer) I tried a while back but no luck. Nobody with a rebel wants to part with their hooks
Bartlert
Bartlert
Edmonton Alberta
Ya that's fair. Probably easier to make some. Thanks for the input everyone.
BWL
Embrace the skeptisism
BC Canada
I use a pair of 6' 2" flat nylon straps to hook both sides. I've seen the closed hooks off the HD break off when pulling hard on just one and I think it's better to distribute the load anyways. I have a tow block I pin into the receiver that has a shackle on it for towing when its facing the other way.
Bartlert
Bartlert
Edmonton Alberta
I've seen that never really thought about it. Thanks for the tip that's probably what I will end up doing. Thanks for the tip
Reactions: BWL
kad
Hudson Valley, NY
5.7L HEMI
This appears to be the part # for the Rebel closed hooks: 68248844AA Same one for Left and Right.
-K
Reticle918
