cold air intake is it worth time?
3pedals
Central Valley
Agreed. If you want more intake roar, may I suggest an Airaid MIT or whatever tube you want to use to connect stock airbox to TB, eliminating the intake resonator box. Have an MIT on my ‘08 4.7 6spd and it doesn’t add an ounce of horsepower, but sounds great and makes the truck more fun to drive
Scott Sanders
Winston-Salem
I have an 05" ram 1500 slt love the truck had to put sone money in Trans rebuild, alternator. now I have been researching a cold air intake. I just want a little more horsepower. is this worth the cost..
Not at all. The only thing it gave me was...1 additional mile per gallon...1.
craigsez
Novascotia,Canada
I didnt read past 1st page but seems its all been said but incase its been missed,i hear the diesel air box is a direct fit and much deeper and way cheaper..
Dusty
Rochester, New York
Back when carburetors were the primary fuel delivery device, there was some validity to CAI. Since at any given steady fuel flow, lowering the temperature of the inlet air could would have some direct impact on air density, but fuel to air ratio would be at the mercy of fixed carburetor jetting. Re-jetting to lower fuel ratio and lower the inlet air temperature will (did) produce cylinder "packing" and a performance gain would be measurable.
Today's fuel injection systems monitor the inlet air temperature and maintain the air fuel ratio across the designed operating range. As you lower the inlet air temperature, whether artificially or naturally, a fairly steady air fuel ratio is maintained. Thus, in this respect, there is no gain to CAI.
Nor does a CAI allow more air into a factory designed intake system on a stock engine. The engine is not an air pump. Air "fills" the engine's cylinders solely by atmospheric pressure and adding a CAI cannot get more air past the engines chokepoint, which in a lot of cases in the throttlebody. Again, as atmospheric pressure changes, modern systems adjust the air fuel ratio accordingly.
There MAY be one advantage that works on some engines, and that is removing air turbulence from the effects of ribbed flex tube inlet plumbing like is used on the Hemis and a lot of other engines. However, I suspect it may be extremely marginal.
Just my opinion, but the only beneficial outcome of CAI is the redistribution of wealth.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 79181 miles
crazykid1994
the amount and design of an aftermarket CAI is MUCH different air flow than the factory for you non performance wanna be mechanics spouting off...
On older trucks or even trucks that use a MAF sensor vs a MAP sensor maybe. A colder reading makes the MAF think there is more airflow than what there actually is since it’s adjusted to the stock reading. Our trucks come factory with a cold air intake setup. Most aftermarket intakes mount to and suck through the fender same as factory. Only difference is the larger filter which unless needed is not beneficial. Heck the 6.4 uses the same size filter and throttle body as the 5.7 and makes 90 more HP? Over the 5.7. Go figure. So performance wise the stock airbox can flow well enough for around 500hp. Isn’t that crazy good for a factory setup. And the air is fairly cold. Some of the aftermarket intakes “seal” to the hood and still draw air through the factory hole or in some instances like the K&N to name one are actually sucking in air from the engine bay because it doesn’t seal to the outside air. Not very cold now. Heck I’m running the 6.4 intake manifold and 6.4 airbox drawing air from a snorkel. My air is 5-10° above ambient while cruising. Why? I’m drawing air from outside directly. Before the snorkel my air was still 5-10° above ambient. Why no difference? Because stock draws air from outside the engine bay.
kidmandudebro
Connecticut
Sorry to hijack but does anyone know were I can buy a replacement K&N filter for my K&N cai I just want the cone filter, not the whole system. I can't find just the filter for sale; would anyone know the dimensions off hand? thank you
crazykid1994
Try contacting k&n
