Hotrod1988
- Joined
- Dec 29, 2015
- Posts
- 12
- Reaction score
- 1
- Ram Year
- 1996
- Engine
- 5.9 Magnum
Hello folks first post here. First I'd like to thank all of you for The wealth of knowledge I've found here as its help me a lot since i bought this truck a couple of years ago. But back to the point, the truck has always had some issues I've been chasing (plenum leak, missfire, clogging cats) but I think I've finally got all that nailed down. Plenum is fixed, miss is fixed, and hollowed the cat out till I can get everything lined out or until it courses other problems.
Currently after fixing the plenum the truck has been running cold. Heater off 174° heater on 169° according to tourqe app. Its cold here in Texas now so its hard to pin it all down yet but the truck idles at 1000 in neutral ones the truck is passed about 140° b4 that it idles normal. I've replaced both the tps and the IAC twice to make sure it wasn't them (they are bwd brand parts) its almost like the truck is holding the IAC open to get it to warm up more but it can't. I may have to go back to the factory 195 t-stat I've used the 180 just because it had one in it when I bought it. However I don't think it ever opens judging by the temp reading I guess the heater core is keeping the truck cool enough in this cold weather lol. Im wondering if having the cat hollow is letting too much heat out and the engine just can't get warm enough? Maybe the t-stat is stuck halfway open? (Its not flowing much in the rad with the cap open tho) I know the engine temp is right as I can put my hand on the head after driving an hour and I can just hold it there. Now the idle may not be related I've read a couple post where people had a frayed wire going to the IAC or the tps causeing idle issues.
Sorry for the long post but wanted to make sure I touch all the bases to delve into the weath of knowledge here
thanks ahead of time guys
