Column Horn Wire
rlmarz
5.7L
Hey all,
Finishing up an air horn install on my '12 1500 ST and have one question. In the wonderful amount of wires coming off the column under the dash, would anyone happen to know the color of the horn switch. Through research I believe it is a negative. Just need it to wire up the stock/air toggle. Thank you in advance.
R
rlmarz
5.7L
BUMP. I've done everything but this..
bassheadhemi
Montreal, Canada
curious too as I want to bypass the truck circuit and use a relay instead to eliminate the stupid horn lag...
