Common issues with the 5th Gen
RAMan92
Virginia Beach, VA
Pentastar 3.6L
Only issue I've had with my 2020 was the notorious driver side interior water leak. Fixed it with silicone. I have the 12.1 inch screen and it's been amazing but I've heard the 2019's with the 12.1 had some pretty bad issues.
FoothillsFixIt
Tucson
No issues with my 2019 Limited. I love this truck! Not sure why I stuck with F-150 for 8 straight pickups, but glad I made the change.
CougarBFMC
D.C.
Hemi 5.7 eTorque
2020 Limited with about 1,000 miles so far. Only issue was a water leak in the headliner above the driver's head, just ahead of the rear-most microphone. I traced it back to water leaking from a hex washer sheet metal screw that was on the forward half of the left side of the sunroof, screwed up from below through the guide frame for the sunroof. I backed it out, shoved some silicone dielectric grease in there, and then screwed it back in with one extra turn. No issues since.
Btp 2332
Curtisville PA
When you guys have your mirror dimmers on, I’m guessing both doors and rear view should dim the same ? My passenger side mirror doesn’t seem dim unless it’s not sensing correctly.
KeithP
Hemi 5.7 VVT
Mine doesn’t either. Son pointed it out to me when he was driving.
BlownGP
BlownGP
Houston/Baton Rouge
You know that's great you fixed it but to me that's something you should not have to do.
Seems like a bad design.
Jus Cruisin
Gearhead
Metro Detroit area after 28 years in Florida
2019 Limited 4X4
E-torque hemi
Just a warranty repair. The dealer could have/would have done the same thing. Cougar was mechanically inclined enough to save himself the time to have someone else do it.
How can you call a loose screw a bad design?
BlownGP
BlownGP
Houston/Baton Rouge
I guess wrong choice of words.
To me water leaking in from a screw seems like something was done wrong from the factory.
CougarBFMC
D.C.
Hemi 5.7 eTorque
Based on what I saw, the design is bad, you're correct. But the time and effort to fix it myself was less than dealing with taking it to the dealer and hoping they figured it out the first time, which is unlikely in my experience.
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
I don't think the passenger side dims. In all my previous Ram's it was only the driver side. Same seems to hold true for this one as well.
Orca
