Confused?
Moparornocar0346
Mount Sterling
5.9 liter
Ok guys quick post. Checking plugs out and I found this on the end of my plug. What is it
Ramnewbie
Not sure if this is the correct name but it's a non fouling plug extender. Apparently that 1 cylinder has been pumping some oil fouling the plug.
OCDTech
Louisiana
^^^^ Yep. Designed to pull the spark plug out of the " Dirty Zone " You can always just screw the plug in without it see what happens but probably foul it out pretty quick but before it does it will smoke some. Had an old Camaro do this once.
Moparornocar0346
Moparornocar0346
Mount Sterling
5.9 liter
Ok well should I do away with it or should I keep it bc plug doesn’t look fouled
Moparornocar0346
Moparornocar0346
Mount Sterling
5.9 liter
Well I’m getting a cylinder 8 misfire that’s were it came from to
Ramnewbie
I'd put in a new plug and if that corrects you're missfire even just temporarily before it fouls again I'd be checking the valve guide seals.
McBroom
Denison Tx
Hemi 6.4L
So far that’s the only cylinder that has one
It’s called an oil fouler. It helps that particular cylinder from fouling the plug because that cylinder is burning oil for some unknown reason
Blue Streak Pearl off-road package
OCDTech
Louisiana
Well ocdtech should I be looking for a donor motor lol
Well, I would try the plug without and with the fouler if you have to. See where that takes you, may possibly have to use the fouler and a hotter plug in that one cylinder. As long as you can deal with it i would run it, but if it keeps fouling or smokes too much then maybe an engine. My problem was my rings but i wanted a bigger engine so i did that.
Moparornocar0346
Moparornocar0346
Mount Sterling
5.9 liter
Well it only smoke when u get into the throttle real heavy or rev it up sitting still.
OCDTech
Louisiana
Can't say for sure but most likely when you get on it. All my years iv'e hardly ever seen a vehicle smoke idling. I had a buddy that had and old chevy 4x4 and it would smoke idling, but not at all when you get on it. Never understood that.
Moparornocar0346
Moparornocar0346
Mount Sterling
5.9 liter
I don’t either but my uncle told me that the plenum could be causing that as well bc it was about 2 quarts low today
OCDTech
Louisiana
While your truck is running pull the pcv hose and see if its is blowing lots of smoke or air. if so thats blow by ( Probably worn rings.)
dapepper9
Iowa/Nebraska Border
5.9L V8
Cylinder 8 fouling is a pretty good indicator of bad plenum.
Somebody found the plug being fouled and rather than fix the oil burn and plenum issue they used a fouler
Moparornocar0346
Moparornocar0346
Mount Sterling
5.9 liter
Bad plenum gasket or plenum itself
Saleen5150
