COOLANT ALL OVER
Dingalinger
minnesota
Hey guys, I just got into rams and I love my 5.7 but I was driving and made it home to steam coming out of my engine bay with coolant everywhere but I dont know what the appropriate course of action is right now, what are some common problems that might help me diagnose my truck it is a 2014 ram 1500 5.7 hemi 4x4
j cal
Check all your hoses
Sent from my SM-N981U using Tapatalk
Dingalinger
Dingalinger
minnesota
I have already looked at as many hoses as I can find but I couldnt find any leaks
Accidental42
Alberta Canada
Check your hoses for cracks, and the clamps for a tight fit. Check radiator fins for excessive damage. Its possible your radiator cap has failed. Those are the easiest things to look at.
Matts175
I would just like to say... if you're adding coolant, make absolutely sure you are adding the correct type. In these 4th gen Hemi Rams, you just can't add any ol' stuff you have in the garage. Mine is a 2015 and it takes "OAT", which is purpleish pink. I would think that your 2014 also takes OAT, but check your owner's manual to be sure.
Accidental42
Alberta Canada
Absolutely! Mine is a 2010 and takes HOAT coolant which is orange. Do not mix the two.
kad
Hudson Valley, NY
5.7L HEMI
I would just like to say thanks for all of the helpful tips it turns out it was the water pump and the thermostat
My '14 5.7 had the water pump go at the end of summer. I see a trend... :)
-K
